Small wireless keyboard
2 Dec 2004
Under The Desk, Wales
Guys, i am in the process of configuring a Small form factor PC and i am after a small Wireless keyboard. About the same size as a Netbook say.
Can anyone recommend one that they have used / tried?
I have a wireless mouse but would also consider a combo of both. Thanks
I use a;
Xebec Tech itouchpad diamond keyboard
I can't link it here, Overclockers used to sell it. It is a good small(ish) HTPC Wireless keyboard.
I use a el cheapo xenta, works fine for general htpc duties, not tried gaming on it and wouldn't recommend for writing a novel but as you can see here it works fine for waffling.
Google "Xenta Super Compact Wireless UK Keyboard - 2.4Ghz Nano USB Receiver" you'll get it off a certain E site for a few pence shy of eight quid.
I used to have a keysonic one but the trackpad drove me insane so went to mouse and small keyboard.
microsoft wedge keyboard, very very nice keyboard, check out the reviews on u tube. real nice quality keyboard
it is small as well just right size nopt too small, either, the keys have a reall good quality feel to them cant recommend it enough
I have used Xenta Wireless Combo Deskset from another site and it's great for the money.
Never understood why this site doesn't really seem to do wireless keyboards, I would never go back to a wired keyboard.
I use the following with my Intel NUC setup connected to my TV
http://www.riitek.com/goods/detail/39.htm
I doubt you can get anything smaller that has a trackpad included as well , range is ok , battery you have to charge about once a month on average use.
You can get them on the rainforest websites for about a tenner.
logitech have some new ones out
forget what they called sorry
we have one of their backlit ones here which i am hoping to steal soon! :)
the new ones are cheaper
Any particular name for them? Or just google it?
