Smaller Case - Advice Required
7 Nov 2006
Hi folks, as the title says I require a smaller pc case but as usual there are some issues and can't pick/decide as I'm more of a hands on person and can't visualise things.
I need something that will hold my current components as I have had to move house and my pc case is just massive (5000d Corsair, usb are also broken at the top some how and Corsair says they don't stock them in the UK any more and won't post from the states).
Kit is:
Full ATX Boards, 5950x CPU (if new cooler is required) PSU, 360mm AIO, 5080 etc.
The 360 I was thinking on replacing for some time now but as it works and works good I would like to keep it if possible for now but if it means I can get a much smaller case because of fitment with it and the 5080 limiting some choices then I'm open to suggestions.
Budgets is somewhat limited. Aka I can't afford a £300 case, but again, I'm open to suggestions.
I hope some of you case experts can help recommend something because when I try to look things up I normally hit a few snags here or there.
Thank you in advance.
