Smaller cooler
27 Mar 2016
Bristolian living in Swindon
Hi all
I currently have the Standard Intel CPU cooler in my Build, I have tried fitting the Raijintek cooler but the copper bits at the top tounch the inside of my case window, Dont like the thought of that so i want to know if there are any smaller Coolers i can buy to go in my Bitfenix Nova case
Thank you
Hi all
Thank you
BitFenix Nova max CPU cooler height is 160mm.
Which Raijintek cooler is it exactly? Wouldn't want to spec you one a similar size which should fit but doesn't either.
Taking up a lot of space is not a problem as long as everything clears. Bigger coolers tend to run cooler and quieter.
Brocken is a good little cooler.
