Smaller mouse?
19 Oct 2010
North Staffs
I've made do with a cheap Cherry wireless mouse for ages, however finally treated myself to a Logitech G703 a couple on months back. While the mouse is better in almost every way compared to the old Cherry, it's quicker, more responsive, with loads more features, it just feels a little too big in my hand. It's a tad taller and quite a lot longer and just not as comfortable after a few hours use. To the point where it's begun to make the centre of my hand a wrist ache a little.
So is there anything out there that a little more petite in the hand. I obviously have Donald Trump 'tiny-hands' and never knew...:):)
P.S... Suggestion don't need to be wireless
Cheers for that. I'll see if I can find one locally so I can take a look at one. I bought this one without seeing one in the flesh, perhaps if I'd had a quick play I may have chosen something else. That said hindsight is a wonderful thing.
Thanks anyway.
G305, G102, Zowie FK2, for example.
Cheers, the Zowie range looks interesting. I'll be honest, in that I didn't realise there mice came in a range of sizes. The FK2 does look interesting as it appears to a have a lower profile, especially when compared to my G703
It will feel a lot smaller. Specs (like length) aren't everything. It's a lot flatter (I have a FK1), and I don't like that, personally :)
If you like the G703 (wireless, Logitech, buttons, ect...) but feels too big, I'd be looking at the G305.
Look at the Zowie ZA13
Over the weekend I was trying to do some comparisons on size, just from dimensions published on manufacturers sites.
Logitech G703. (124 X 68 X 43) Length, width, height.
Zowie FK2 (124 X 60 X 36)
Zowie ZA13 (120 X 58 X 38)
We are only talking millimeters but the G703 is the largest of the 3 I've looked at. I think it's actually the height of the Logitech that I find uncomfortable, length wise it feels OK. The FK2 looks give or take about 7mm lower. I guess I need to try before I buy next time.
The Roccat Kone Pure is also a smaller mouse. Fits great in my smaller hands
Width 7.0 cm , Height 3.9 cm , Length 11.5 cm , Weight 93 g
The height goes a long way into feeling 'big'. The zowies are slimmer (too slim for me) and shallower, and they feel smaller.
Zowie should upgrade their ZA / FK series to the new 3360 sensor. I'd keep an eye on that.
