panasonic has just brought out a 4k hdr firmware update out for their gh5 lumix camera allowing you to record cinema 4k films and 6k anamorphic films both in hdr and i require a way to view the footage so i can edit it.
due to the fact i allready own a good non hdr panasonic 65" 4k 3d tv that i do not want to replace, i was going to get a smaller screen to view the footage one, does anyone recommend a small 4k uhd hdr screen that is good better quality than the sub £400 screen or are there any at that price i should consider was thinking max £500-£600 and is there any good enough for replacing my current 28" lg 4k monitor ?
thanks
thanks
