Smallest and windowless mATX
11 Sep 2013
Hi there,
Can anyone suggest a mATX case that is as small as possible with no window. I like the cube or HTPC style designs.
I have some in mind but just seeing if anyone has any other suggestions that I've missed.
Will be using 1070 GFX and most probably Corsair CSM 550 PSU.
Cheers
I have used both cases below. the BitFenix Phenom looks great, VERY hard to build in tho, you need to watch you tube videos they are that complicated.. note the other BitFenix MATX Cube cases are pretty much the same interior design. The Antec one is very easy to build compared to the BitFenix. its a bit disappointing in the quality with a thin singles piece steel cover, and the plastic power and reset buttons. but it does look neat.
My basket at Overclockers UK:
Total: £145.24
(includes shipping: £12.30)
The BitFenix Phenom is at the top of the list right now. I like the way the components are organised but yeah it does look like a B to build and organise cables... Luckily I'm a patient person.
I was looking at the NZXT Kraken X42 as a CPU cooler as I really don't like the big block air coolers. Anyone used the X41/2 in a BitFenix Phenom M which uses a 140mm rad/fan successfully?
Sorry I should have mentioned, has anyone used a 140mm rad/fan successfully at the back with a 230mm or 200mm fan at the bottom?
I've a Cooltek U3 which is tiny. Fits a matx as system with a decent GPU. I've a gtx680 in mine :)
It's not pretty inside, but it's windowless, so no one sees it!
Really nice build quality too. In a similar vein of build/design as Lian-Li.
