Smallest ATX Case for Thread Ripper Build
7 Aug 2004
As title - I am beginning my parts research for a Thread Ripper build - but I want this as small as possible, while still having decent functionality.
Ideally I want the smallest quietest case - obviously it wont be as small as ITX/M-ATX but still as small as can.
Perfect world:
Supports 240/280mm AIO Cooler
2 3.5" hard drives
As silent as possible (I'll install the best fans I can fit in)
I'll be going NVME on the build for the main boot/work drive, but ill have a 10TB drive or 2 for large storage.
Any pointers?
Fractal Define C? :) it is quite small and panels looked impressive to me in terms of blocking the sound off.
Check out the Jonsbo/Cooltek range... they do some of the smallest and classiest looking ATX cases you can get, but they aren't cheap. The aforementioned W2 has been discontinued now, but you can still find it in a few places.
The S340 is a great case, but it's not exactly 'small'... you can get something more compact than that.
