SMallest ATX Case (i.e. not SFF)
Permabanned
8 Jul 2006
Google Earth
Hi I just want to ask if anyone knows which is the SMALLEST ATX case I can get atm.
I want to see what I can get without getting an SFF PC
Thanks.
It looks very good aswell, a thread with some pictures in floating about this section.
Search for black lanboy and it should come up.
They look stunning, have quite poor cooling and cost a fair bit, I think the G50 is the better of the two.
Although the v600 is a contender for the best looking case ever.
I've actually got the cooling within acceptable bounds now - the Conroes run so cool, the crappy airflow doesn't actually matter anymore. And it is soooo good looking.
Thats cheating a bit as you halved the heat output, but I know what you mean, 3700 at 2.8ghz with 1 case fan at 5v in the Sugo, yet the Athlon XP was about 40deg hotter with the same fan config. :p
Every case has a use, but I can not see why you would take a v600 over a PC7+ just purely on being able to hold a system, looks aside.
You can't ignore the looks, surely. One is a well made square box and one is a thing of utter beauty. I've got all the drives stealthed with the proper panels and it just looks smooth. Plus it's black and we all know black is best!
Riiya said:
Lol :( Thats what I use right now!
Wish it didnt have the side window tbh though :P
Just swap the panels :D
