I had put the fractal pop air into my basket during the night and to be honest not much in the size,Something like the Raijintek Thetis is probably the smallest, but it's probably a bit too small and therefore compromised for decent hardware.
If you go slightly bigger then something like the Jonsbo D41 has a bit more useful space and several options for mounting the PSU to fit larger gpus etc
Jonsbo D41 Mesh Standard ATX PC Case – Black, Tempered Glass
Order Jonsbo D41 Mesh Standard ATX PC Case – Black, Tempered Glass now online and benefit from fast delivery.www.overclockers.co.uk
RAIJINTEK
Raijintek provides the products - high compatibility, extreme engineering, remarkable performance, amazing design, necessity of demand and multifunctional usage – for high recommendation everywhere to make up your life.www.raijintek.com
This might be another great option as never heard of this brand, thanks for the informationWhat are the other components and uses?
Meshroom s is great but has compromises.
Thanks this is what I was going to buy but don't want to have buy a smaller mobo lolYou could go MATX and get something like Lian Li's A3.
It supports ATX PSUs and can fit reasonably sized air coolers.
Did an atx build with the Meshroom. Limited to a 90-ish cm cooler if going air, SFX/L PSU, 3 slot gpu and 38cm riser cable.This might be another great option as never heard of this brand, thanks for the information
RAIJINTEK
funny enough the jonsbo was one of the cases i was originally going to buy when planning a sff build. the meshroom was also on my list I ended up with a nr200 and went itx but them cases are great the fact you dont need to use sfx and atx psus are compat depending on their sizewith this case i would just say watch GPU compatibility, my brother as the LCD model of this case and is 3070 Aorus Master only just fits.. it not a big GPU
Hi all
Does anyone know whats the smallest case I can buy that will support an ATX mobo like
ASUS AMD ROG STRIX X670E-A GAMING
Thanks
completely agree I ended up buying a used sfx psu off the MM, my only problem now is being power limited when looking at replacement gpus to replace my 1070 starting to show its age in some games. I was super close to the jonsbo but my evga psu would have been too big as its a big psu, the front display looked nice for using it as a build in frame counter. the meshroom would have blown hot air back into my case because my 1070 is a blower fan too the nr200 just seemed more easier when factoring all that in as id still need a new psu.NR 200 is a solid case, my only problem would be the ITX psu when there is smaller cases that will use a standard psu.
an ITX psu is an unnecessary expense.
