Smallest ATX case
7 Jan 2010
Portsmouth
Hey
For a bit of time I have been considering selling my PC to buy an alienware laptop, but since its the portability of the base unit being the problem and not hardware spec, Ive thought perhaps I can get a smaller case for my PC. This is a bit of a weird one, but I wanna swap all my components to a smaller case and therefore want the smallest full size atx board case I can find. Ideally I don't want to change my motherboard hence the full size atx, unless by sheer luck there is anyone out there that wants to wants to do the opposite to me and swap their mATX and case for my ATX and case? (P55-UD4 / NZXT Apollo) Otherwise just helping me find an ATX case would be awesome :)
I'd either be looking for an HTPC/Laydown style ATX case, or getting something like this
Or keep on the lookout for a Coolermaster ATCS 500.
To be fair, if you put your motherboard up on the MM i'd have thought you'd get or get very close to the budget required for a nice mATX or mITX board which would take your processor.
That just leaves buying a suitable smaller case and you're laughing. :)
And trust me, you can get some serious power in a small case. ;)
