Smallest case for ATX motherboard?
6 Jan 2007
Hi,
Please may someone recommend me the smallest case I can buy for an ATX motherboard? It's a Gigabyte Z97X-Gaming 7.
The problem is I have a Sapphire Vapor-X R9 290 graphics card, which is long. I just measured it now and it's around 30cm in length!
Right now I have a Cooler Master COSMOS as my case (which is huge and heavy) and things barely fit in that, so any suggestions are most appreciated...
Thanks!
The Phanteks eclipse P400 is reasonably compact and looks quite cute - plus you can easily do custom lighting inside.
Not the smallest but you get a choice of sound dampening if you want it, it's got a fan controller and built in colour change lighting. Should easily fit in your gfx card too.
You can pick them up quite cheaply - I've seen the sound dampened window version for £55; if it took a rad in the roof I'd have already bought one.
