Smallest case for full size mobo / gpu
10 Jan 2011
Hello all
I'm looking to safe room and move my of into a nice small case to maybe go into the lounge under the tv, what's the smallest case that houses full size mobo and gpu its a gtx680
Silverstone Grandia GD09 Home Theatre Server Case - Black (SST-GD09B)
440mm (W) x 170mm (H) x 358mm (D), 26.8 lit
I had one of them ,just fitted between the 2 glass panels of the HDTV stand ,depending on stand , the case above the smallest out of them sort of cases & always goes out of stock fast being good & great price, hope this helps .
another case ,this time a midi tower ,one of the smallest and takes Normal ATX
Lian Li PC-A51WX Midi-Tower - Black/Black Window
Dimensions: 230 x 393 x 489 mm (W x H x D)
I did a similar migration earlier in the year to a Fractal Design Node 605.
Takes a full ATX mobo and GPU upto 280mm (gtx680 will fit).
WxHxD = 445 x 164 x 349mm. The clincher for me was the depth as my TV stand has a built in cable tidy and I don't think the Silverstone models at the time would have fit.
