smallest case for GA-Z68AP-D3, maybe an mATX
5 Nov 2010
Hi, I have been given back a pc I built for my sister in 2012.
I am thinking of reusing the components for my son as his first PC that can sit next to mine in the office.
The motherboard is a Gigabyte GA-Z68AP-D3 which is ATX but only 22cm x 30cm
Ideally I would like to put the mobo in a cheap mATX case but appreciate holes wont line up, the case will be hidden away so not afraid to go all "dremel" on the case.
has anyone managed to jimmy an ATX into an mATX case that can offer some advice? will the ATX PSU fit internally as well after some modifications?
I am looking for a case that is no bigger than 35x35x35cm
Thanks
