Smallest case to fit Gaming X Trio 2080ti and Kraken X62
21 Jun 2006
UK
I'm looking to downsize my desktop as we have a little one on the way.
I currently have a Fractal R6 which I'm really happy with in terms of looks/performance but would like to free up some desk space.
I would like to fit the following;
MSI Gaming X Trio 2080 Ti (327 x 140 x 55.6 mm)
NZXT Kraken X62
32GB Team Group Dark Pro (4x module)
Appreciate I'll need a new motherboard too.
I don't think you can fit those three together in any itx case, you can fit the gpu in a H200i, but then you would need a single fan AIO, and probably mid-tower cases are already the size of your fractal r6
NZXT Kraken X62
I've just been looking at exactly the same thing! I have the same card and case, but with a Corsair H100i AIO and 4 sticks of Corsair Vengeance Pro ram.
Seems a larger case would be better for that GPU, just seems too thick and air flow won't be that good in a H200.
FormD T1 can fit a triple slot GPU and an AIO. Doubt it will be cheap.
https://www.youtube.com/watch?v=Ou4iWsBNSmY
Think you will need to go Matx since you have 4 sticks of RAM.
Cerberus is probably the smallest.
https://www.youtube.com/watch?v=4mhKJ1gtKi0
There's also the Fractal Meshify C. I was considering this case a while back. Not too expensive and looks to have decent thermals. Not the smallest but it looks quite nice in my opinion. (skip to 0:50 to see how a build looks inside.)
https://www.youtube.com/watch?v=mEkS32aGJRc
https://www.overclockers.co.uk/frac...i-dark-tg-micro-atx-case-black-ca-081-fd.html
