Smallest rtx 3080
6 Dec 2007
Cambridge
Hi all
I'm a bit tight for space in my current case (Jonsbo UMX4 Pro) and have 310mm max clearance. Can anyone point me to a small rtx 3080?
So far I've found:
FE - 285mm
MSI Ventus 3x - 305mm
Palit Gaming Pro - 294mm
Asus Tuf - 299.9mm
My main concern is fit, but I'd prefer minimal/no LED bling.
Thanks!
My 1080 Palit from 4 years ago lets me set it: Off, GPU temperature, Still, Rainbow and then there is a tick box to make it do that by default on boot up (in Thunder Master).
Check the zotac dual fan card. Normally they are smaller but that does come with a tradeoff of being not the best
Sorry to hijack but saves a new thread for such a simple question. Would a 3080 FE fit in the h510 elite with an x63? I have looked and I think it does but maybe one of the pros can confirm before I purchase the 3080 when released.
"We have even more GeForce RTX 30-series graphics cards in the works, including a handy Turbo design that exhausts hot air directly from cases. It’s perfect for small-form-factor builds or enclosures that can use a helping hand in keeping system temperatures in check. Stay tuned. "
https://rog.asus.com/articles/gamin...-geforce-rtx-3070-rtx-3080-rtx-3090-rog-asus/
This is great news as the new cards are too long for my case! Also turns out i don't like the stock nvidia design this release either so if ASUS can release a slightly shorter 3080 with a nice cooler, that would be amazing.
Hi all
So far I've found:
FE - 285mm
Asus Tuf - 299.9mm
Thanks!
Had that case, with Strix 980ti.. just haha
Aorus haven't released details yet but they had one of the smallest Flagship cards due to stacking 3 100mm fans .. this time around its 115mm fans stacked so guessing gone from 284mm to 300mm odd :/
Thanks - the Strix was 305mm, so I'm guessing Jonsbo's official 310mm is a bit generous?
My case supports a max GPU length of 320mm and the 3080 variant I want to buy is 323mm. Looks like I need to turn into metal bender xD
Like someone else said, Zotac has the smallest card.
