Smallest size case a standard motherboard will fit in?
1 May 2007
Manchester. UK
Pretty much got the spec together for a new pc, was going to put it in a shuttle but very limited by available motherboards. So, was thinking what is the smallest case available that can house a half decent core 2 duo motherboard?
Needs enough room for a h/d, DVD drive, Geforce 8800 GTS and a CPU cooler.
Reason I need it small is that it needs to be as portable as possible - lugging a big tower from house to car to hotel then back to the car then back home again every week would be a pain in the arse!
shuttles come with their own motherboards, PSU and cooling just to let you know. also with the amount of travelling/lugging why not get a half decent laptop, would be much easier :confused:
sounds like you need an matx board, look at the silverstone sugo & the lian li range. I have just bought an abit f-i90hd board and am waiting on the sugo sg03 case to be released :)
mountain mods bobslay case superb , i can fit full size atx mb and 8800 gts 3 hd's and full size psu . and because the mb is seperated from other components and lies horizontal i found my temps dropped quite a bit as well ,plus it has a carrying handle to boot. it measures h 305mm w 282mm d 373mm ,another plus was because off the size i can use noctua 800 rpm fans to keep everything cool which means the only audible noise is now my cpu fan (working on that one )
You could get an mATX case like a Silverstone Sugo, and an mATX Core 2 Duo motherboard. The problem is that there are no mATX Core 2 Duo motherboards to match the overclocking potential of a full ATX board.
You could go for a small full ATX case like a Lian Li V600, G50 or PC-A05. :)
If you're looking to use a non-stock CPU cooler, be carefull when looking at the G50 or V600, as the power supply is mounted right in the space that a big tower style cooler would take up.
I have a G50 running with my old Athlon stock cooler, and thats about as tall as i'd want to go to keep a good airflow, but every now and then I find myself longing for quieter alternatives.... :rolleyes:
That aside I just love the size and pure looks of the thing.
PK!
Antec Super Lanboy would be a good choice also uf you could find one. Fits a full sizes mobo and i had a 7900GTX in mine as well :)
I looked into shuttles, but even the top of the range mobo for it doesn't support 800mhz ram which I've just bought :(
I wouldn't want a 'half decent' laptop, I wanted one that would be good enough to rival a desktop, but they are just to expensive.
Liking that super lanboy case! Trying to find one though isn't proving to easy...
Keeping the cables tidy in a Super Lanboy can be a bit fiddly (to say the least), but it is lightweight.
It comes with carry handles, but they're not worth the effort.
