Smart chargers and really flat batteries
2 Aug 2012
Modern smart battery chargers will not start charging unless there is a minimum terminal voltage present.
Which presents a problem if one is attempting to charge a really flat battery.
One can get round this by putting a good battery in parallel to the flat one to get the charger to cut in.
But this can be a bit of a faff.
Does anybody make a charger that can be overridden in some way to allow a really flat battery to start charging??
25 May 2008
North Wales
Isn't the reason they won't charge a really flat battery is that when a regular car battery goes below a certain voltage (anything lower than 10.5 volts usually) it'll be permanently damaged and won't ever hold a charge properly so you should really just replace it at that stage.
OP
2 Aug 2012
Shouldn't be, I have recovered many batteries from far lower states of charge than that and they have subsequently tested out just fine with my Midtronics type tester (Conductance tester) and they have worked just fine in practice.
Sure, deep discharge can destroy a battery, especially if it is left that way for weeks on end, but a flat battery from leaving the lights on overnight (Say) which can easily discharge to below 6 volts is usually recoverable with no obvious long term damage if the battery was previously otherwise OK.
20 Feb 2011
My two smart chargers have options for regenerating completely flat batteries. Only have to use the option a couple of times but it worked. May be worth checking the manual to see if your charger has similar options.
18 Oct 2002
Nah that's nonsense, I've charged multiple batteries from completely dead and gone on to use them without issue for years.
26 Jul 2010
Wiltshire
You can use a 9v PP3 to start the charge instead of another 12v in parallel.
The reason why it won't charge without a voltage present is to prevent the charger leads shorting together when not connected to a battery, if the charger is plugged in to a wall socket that's switched on.
OP
2 Aug 2012
Mine has a similar function, but it still wont cut in below 6 volts or so. I am guessing it is to do with reverse polarity protection. Below a certain voltage, the charger cant make the connection to even see that a battery is present.
(I dare say more expensive smart chargers are somewhat smarter than mine)
Obviously, if one did have a manual override, one would have to use it very carefully
And yes, I did come across somebody once who had managed to charge up a dead flat battery the wrong way round using an old fashioned "Dumb" charger. Surprisingly it did work really quite well afterwards, but just with the polarities reversed
Man of Honour
17 Oct 2002
Ottakring, Vienna.
Whilst I'd broadly agree, that's becoming less and less true. I'm not sure what's changed over the last few years in modern lead acid batteries, but they really don't take multiple discharges like they did 10-15 years ago - particularly at the lower end of the market.
Even if they recharge to 12V, quite often the CCA is completely shot.
1 Mar 2010
I've had a similar issue changing nimh in houeshold products - razers/toothbrushes
they are adding calcium and other alloys, even in cheaper batteries electrodes, that may make them less resilient if you don't have a smart charger limiting the current
18 Oct 2002
It's funny you should say that. I would say my experience is the opposite, years ago a deeply drained battery would be toast but the newer ones from the past 10 or 15 years seem to take well to a recharge. I've never used anything more than a 4A charger. I only recently got a 'smart' charger, as mentioned in the OP, it's annoying you have to jump the battery the make the charger kick in with it.
18 Oct 2002
Devon
The reason chargers want to see a minimum voltage before they start charging is simply down to polarity protection.
1 Mar 2010
*mild reboot*
Any recommendations for a mains trickle charger via cigarette lighter ?
Older neighbour has a Ford Ka, used irregularly for short distances - they're not too worried about the wear on the car, but could do with something in the garage to just plug in when they garage the car.
Can you just get an adapter for a smart charger ?
interesting - hadn't realised ctec smart charge was so complex
15 Nov 2005
Newcastle
*mild reboot*
Is the accessory/cigarette lighter socket constantly live in a Ka? If not and it's only on with the ignition then charging it via the socket won't work.
If it is constantly live then ctek sell an adapter that works with all their smart charges up to 5a
1 Mar 2010
indeed I need to check cigarette lighter is live;
neighbour wouldn't be able, to delve around under the bonnet, for attaching battery clips.
Maybe ctek's are well 'protected', but I would never charge a battery in the car, without removing its earth/car connection, first, too, just in case the charger sent some pulse to the ecu (would your fully comp car insurance cover that, i guess so),
on the other hand, if it were a dedcated cigsarette trickle charger, I'd expect it to avoid that issue.
1 Mar 2010
In my case neigbour is 75+ years old, takes the Ka out for short trips, where more charge is lost, than gained,
they are best of friends with the AA home-start, and wouldn't be able to remove battery ...
(hell) it even annoys me if I have to reset the clock, and the presets on the car car radio.
