Hi all,
After a bit of ‘Smart Home’ help.
We are in a rented 2 bed flat with electric only, no gas whatsoever ☹
Currently have a number of Google Homes (3), Hue bulbs and motion sensor, Harmony remote and hub and a smart plug.
We currently have electric ceiling heating and safe to say it’s rubbish. After 4 years of trying to get it to work efficiently we have given up with it and it’s massive electric bills.
We are now using a couple of oil filled radiators to heat our flat (2x2.5Kw). So far it’s working out well and using far less electricity than the ceiling heating.
Fortunately the flat is very well insulated as a result of having the ceiling heating.
We are currently using a normal standalone digital thermometer on the sideboard to gauge room temperature and then either use the mechanical timer on the oil radiator or just turn it on/off manually if we are home if we feel it is hot enough/cold in the rooms.
I would like to make it much smarter so we can schedule the ‘heating’ to come on/off more accurately (day/time) than the oil radiator timer but also better control based on room temperature.
My thoughts are that if I can get a ‘smart’ Wi-Fi thermometer / thermostat and link it with IFTTT or similar to a smart plug then we can effectively make a ‘normal’ heating system in the rooms.
If temp is below X, turn on smart plug. If temp is above Y turn off smart plug but only between times A and B in the morning and C and D in the evening etc.
Can anyone advise on an IFTTT or similar compatible ‘smart’ thermometer / thermostat? Or is there another way I haven’t considered.
Many thanks
Many thanks
