Smart Plug max wattage
21 Mar 2016
Devon
am I correct in thinking the max wattage for this smart plug is 2500w?
https://imgur.com/a/TSUt1N1
TSUt1N1
The rated current should be on the switch itself on the label. You can't rate it by the relay as there may be other factors limiting the current like the wiring to the relay.
I wouldnt put any more than 10Amps through any smart plug. If you need to switch larger loads, use a contactor.
