So I've changed many switches in the past with no issues as the number of wires is usually simple to work out but in my recent home, I opened up the socket to replace it with a Sonoff T3-Black and it's completely baffled me with the amount of wires I saw behind it.
In the living room there are two lights which are controlled by the switch I'm trying not replace. On the other side of the room there is another switch that only turns off one of the lights.
Here is the back of the current light switch and the wires.
(Top brown is Common, Left is L1 and right is L2)
Now for the smart switch, I have the Neutral wire (blue, currently not in use) and live (Common wire in old socket). The remaining output is L1 out. Do all the wires go in that? Surely not.
Diagram for the smart switch below.
Thanks
Thanks
