Smart Thermostat - Tado Vs Honeywell T6
18 Oct 2002
Livingston
I’m looking for some advice as to which smart thermostat I should look at to replace my Nest Thermostat v2 that I currently have.
I’ve been using my Nest Thermostat and Nest Protects fairly happily since they begun to be sold in the UK about 4-5 years ago. With the only problems being the original Nest Protects removal of the Nest Wave feature (had my v1 Protects replaced with v2 for free) and Nests continued reluctance to add Apple HomeKit support.
The reluctance by a Nest to add official Apple HomeKit support had been resolved by using HomeBridge with the Nest plugin. I’ve had my Homebridge server setup on a Raspberry Pi3 for the past few years without an issue. This allows me to have my Nest Thermostat show up in the Home app on my iPhone and I can use Siri or the Home app on any of my Apple devices to make temperature adjustments.
It’s been announced by Google this week as part of a reorganisation of Nest within Google that the ‘Works with Nest’ program is to close, which gives access to the developer API’s that makes the Nest HomeBridge workaround work and there isn’t going to be a replacement.
With this being the case I’m looking at replacing my Nest equipment, starting with my Thermostat.
The options I’m looking at must have Apple HomeKit support which limits my options to the Tado v3 and the Honeywell T6. I have a Worcester Bosch 38CDi combi boiler.
I’ve had a look at Tado and I would need to buy both the Thermostat and the Extension kit as I don’t have an existing direct connection between the two. Is it recommended to buy radiator valves at the same time to achieve maximum efficiency?
Would every room radiator with an existing TRV require one, how does it work with larger rooms my kitchen has two radiators both with TRV’s? What about heated towel rails?
Does anyone have a Honeywell T6, if so how do you find it?
