smf forums
i've just installed it for a new site. never used it before (as an admin). how do you change the board title from "my community" in the top-left to something else?
can't believe something as simple as this isn't obvious in the admin cp, like it is in phpbb. :/
I just replaced the image with mine
it lives in ....
/Themes/classic/images/smflogo.gif
saves messing around
i forgot to say
SMF ain't as easy as something like IPB
coz if you want to modify the template .. you gotta dig for a it a little
whereas with IPB it's all in the admin section
not in SMF.
changing an image is easy, you just follow the path, but it's text that i want to change.
ie, at the bottom of the board is this copyright message...
My Community | Powered by SMF 1.0.9.
© 2001-2005, Lewis Media. All Rights Reserved.
it's "my community" which i want to change.
the same name appears in the top-left in large letters (again, it's text, not an image). I shouldn't have to manually change this in the php files, there should be an option in the admin cp somewhere for changing the title of my board. :/
guess not though...
and just to make things worse, whenever i try to post at the smf support forums i get this error message...
Fatal error: Argument 1 passed to notifyMembersBoard() must be an object of class h�>��<�Q��Q��F��:�շ�շ�շ�շ�շ�շ �շ �շ(�շ(�շ0�շ0�շ��O��O@�շ@�շH�շH�շP�շP�շX�շX�շ��O��O8.88.8p�շp�շx�շx�շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ��շ, called in /home/simple/security/Sources/Post.php on line 1782 and defined in /home/simple/security/Sources/Post.php on line 1996
i'm tempted to go back to phpbb already!
