Hi
i have created a smil animation and i am trying to embed it into my html. I am using the following code. when testing on local host everything works fine. when i upload to my webserver i get the following error :
a general error has occured :
mem://057DDAF0/wwwusers.brookes.ac.uk/04106649/smil/slide1.jpg
i have search lots of websites but some give totally different methods that are not useful i believe.
anyhelp would be really much appreciated.
thank you
thank you
Code:
<object id="media"classid="CLSID:CFCDAA03-8BE4-11CF-B84B-0020AFBBCCFA" width="600" height="300"> <param name="src" value="smil/SMILe.smi">
<param name="console" value="Clip1">
<param name="controls" value="ImageWindow">
<param name="AutoStart" value="TRUE">
<embed controls="ImageWindow" console="Clip1" type="audio/x-pn-realaudio-plugin" src="smil/SMILe.smi" width="600" height="300" autostart="true">
</embed>
I take it you did the SMIL animation for the Multimedia Application Design module... Did you ever get this working in the end as i'm having exactly the same problem!
