Smoke/emissions testing for diesels
5 Nov 2004
I took the Diesel for the mot yesterday at a local garage and when they did the emissions test they just held the throttle to the floor until either the rev limiter cut in or valve bounce occured. Personally I don't think this is either necessary or the correct way of doing it. In the past when I've took the car to the Ministrys own testing stations they rarely rev them past 4000rpm and on one occasion the ministry tester told me off for over revving the engine.
Does anyone know the correct proceedure they should use apart from the ' test it to destruction' method ?
If valve bounce occured then you either have a seriously high revving diesel or the valve springs have been taken from old biros, it simply won't happen. Diesels have a very low rev limit, unless the engine is at deaths door there is no problem with taking it up to the limiter.
cymatty said:
Do thet do the same for petrol engines?
Unless things have changed a great deal since I was in the motor trade, Petrol cars have their emmisions checked at idle speed and normal running temperature. They might rev them slightly just to clear them before or during the emmisions is checked.
I'm not clear on the Diesel test because the firm I worked for back then only worked on petrol vehicles.
the difference with a diesel engine is many owners think their engine is killing itself when revved like this.diesels just sound that way when revved hard and no damage is being done unless you're low on oil.
unless i'm mistaken you physically cannot get enough fuel into a diesel engine to allow it to rev upto valve bounce.
As long as its reasonably well maintained, with a good cambelt and up to temperature, a little revving won't do it harm, though I would probably cringe if it were my car/van on test.
I regularly redline my car when extracting maximum performance but sitting outside the car hearing it bounce off the limiter in neutral doesn't sound nice at all.
I don't have a problem with the car being driven hard but, to hold it with the throttle full open and no load on the engine is neither sensible or healthy to the engine IMHO.
The other thing is its not really a true reflection on the cars emissions in normal driving because, in normal driving you never need to exceed 3000rpm.
Diesel engines are tested at full throttle. This is the only way of getting the correct reading. If you don't like it then buy a petrol, they are tested at idle and then for approx 40 seconds at 3-3500 rpm.
if running without load damages an engine how are some engines "bench run-in"?
that's nonsense.
in a Turbo Diesel the turbo won't come on song until approximately 2500RPM.
obviously the engine needs to be tested to see what emmisions are like at the higher end of the rev range.
Probably because they ain't held at 6000rpm +
The_Dark_Side said:
that's nonsense.
Thats also nonsense because, the point of the turbo being 'on song' is dependant on the vehicle and its design etc. A nova turbo diesel comes on song at 3000rpm . A 16 litre truck engine would have a turbo spinning like a whirlwind at just 1000rpm.
Opening the throttle on a diesel engine only regulates how much fuel is injected , the only way to test it's emissions is to inject the maximum allowed into the engine & that is ONLY going to happen at full throttle hence a diesel smoke test has to be done at full throttle, Some basic checks are carried out before the test is done which include oil level, bringing the engine up to normal running temp but most importantly the cambelt history has to be taken into account, The presenter of any diesel car should be given a card at reception stating what happens during the smoke test & if there is any doubt or the presenter can't confirm the cambelt history the testing station can & will refuse to carry out the test.
For the record the engine is held on the governor for aprox 5 seconds , if the smoke reading is within the limits after this time the car passes & thats it, this is known as "Fast Pass" , If if fails then the test is carried out up to a maximum of 6 runs & a mean average is taken , more often than not the first test run can be quite high especially if the car only pootles around as there is a buildup of soot in the exhaust which needs to be cleared out.
nor are 90% of diesels as they don't rev that high.
the amount of fuel fed to the engine determines how high it revs therefore you cannot rev a diesel past it's safe working limit.
notice the word APPROXIMATELY in my post.
now let's address your reply shall we?
according to you there is no need to rev higher than 3000 RPM in a diesel car.
if that's correct,and you are also correct in your Nova TD example then can you explain why the manufacturer constructed a vehicle with a turbo that according to you would be un-necessary to use?
fairly obvious as many truck engines won't even rev to 3000 RPM
Erm, What I actually said is there is no need to rev MY car higher than 3000rpm because its passed the point of maximum torque produced. My car is normally aspirated so nothing exciting is gonna happen however hard its revved.
My point of comparing a Nova to a truck is that you can't generalise all diesel vehicles as being the same and having the same power bands.
If you take the governor off of a diesel engine (at least, on one's with the mechanical injection pump) then it would just keep climbing up the revs until self-destruction. Whether it would blow up before the valve bounce I'm not sure. :p
