Smooth mouse option question
18 Jan 2003
Expat in the USA
GPU is 980GTX
Without this option on playing COD games MW3 and Ghosts, there's a significant amount of stutter when moving the mouse. (VSYNC on) Cant bear to look at a screen without vsync on..
anyway, turning it on, seems to fix...
Why is that ? Why is it off by default ?
And most importantly, if i drop lots of dosh on a g-sync monitor, does it fix this kind of stutter ?
First question has to be why are you playing the worst cod games?
Mouse smoothing is the interpolation of mouse movements so that it is no longer 1 to 1 plus it adds lag as it waits for multiple movements before merging them into 1 smoother movement. All around a bad idea.
You might be stuttering because the mouse isn't tracking correctly. Check for dirt in the sensor.
