I'm having one of those days where things are just not doing what I want them to do
Trying to get a smoothscroll to work but it's just not liking me for some reason and it's even more annoying when it's worked before on another site design I've used it on
The only difference is that I've now got a sticky header and sub nav section.
Anchors are all working as they're supposed to, ie it scrolls the 'text part' to where it's linked but it doesn't have the offset and smoothscroll (script would fix this).
Layout of site is (id's in brackets)
div (header) with nav (id)
div (sub-nav) with nav (sub-menu) linking to anchors
div ("wrapper") with class (white) - "wrapper" is different on each page although that can be changed to the same if needed.
div (anchor)
div (anchor 2)....
jquery script I've used that worked before is below... am I missing something completely obvious to get this to work
As a side note: does anyone know of a way to adjust offset to em's rather than pixels, my headers are in em's rather than percent/pixels so they scale with the text etc?
Thanks in advance
div (anchor)
div (anchor 2)....
Code:
$(document).ready(function() {
// Click event for any anchor tag that's href starts with #
$('a[href^="#"]').click(function(event) {
// The id of the section we want to go to.
var id = $(this).attr("href");
// An offset to push the content down from the top.
var offset = 75;
// Our scroll target : the top position of the
// section that has the id referenced by our href.
var target = $(id).offset().top - offset;
// The magic...smooth scrollin' goodness.
$('html, body').animate({scrollTop:target}, 500);
//prevent the page from jumping down to our section.
event.preventDefault();
Thanks in advance
