I know the feeling - not much I can do to avoid it eitherMGP said:Looks like I won't be trying that then. Still got to do something to minimise the stompings that are heading my way![]()
rich99million said:I know the feeling - not much I can do to avoid it either![]()
I've chosen the GPU client alongside a standard client on my X2 as the WinSMP client produces about the same anyway - just got the GPU client working again after my machine had to be turned "not on" for the weekend and it threw a bit of a paddy (seemed to be a driver issue so I've upgraded to 7.2s incase I ever play a game on it).
If it stays happy overnight I may have to get the Acelero cooler attached and try for some higher clocks![]()
I decided to try and run away very fast, which has at least got me some short-term benefit, but I'm not sure how long it'll last.rich99million said:I know the feeling - not much I can do to avoid it either![]()
2bullish said:I get about the same using SMP or cpu + gpu clients. I find it much easier using the smp as running the gpu client 24/7 effects browsing. If I want to game I have to switch off the gpu but with smp it simply idles. So much easier using smp.
lolBerserker said:I decided to try and run away very fast, which has at least got me some short-term benefit, but I'm not sure how long it'll last.![]()
