SMP2 client showing wrong time - a problem?
25 Dec 2008
Sheffield/Norwich
Just noticed my SMP2 client is on GMT instead of BST. I don't think this is actually going to cause a problem/less PPD because everything relating to that should be done on the servers, but am I wrong? And if so, any ideas on how to fix it? I've checked and it is set not to ignore host time, or whatever that setting is, in advanced options.
Cheers.
Yep, the time is always UTC. I think it's in case you want to send your logs for troubleshooting - makes it easier if all logs are in the same timezone.
