SMSL SA50 Amp
20 Oct 2002
Anyone use one of these amps ?
I picked up one recently, if there is no audio input and I power on the amp I can hear a faint hiss / static sound from my speakers if you are close to them.
This does not change with volume.
I was just wondering if this is normal for the amp, am I hearing the hiss due to the sensitivity of my speakers? or do you always get this with these amps ?
The speakers I have hooked up to it are Micca MB42
How loud is it?
You do get some noise with amplifiers, but generally, I would expect that it would only be heard when you have your ear close to the speakers.
Having said that though, I have a Topping TP21 which is also a Tripath amp, and I can't hear any hiss at all, even with the volume pot opened right up. There is a hiss though with my integrated amp, which does increase as the volume pot is opened up.
I'm not sure what part speaker sensitivity plays when it comes to noise. I would expect hiss to be louder with more sensitive speakers, as they can generate more volume at the same input level than less sensitive speakers. The speakers I use with the TP21 are 88dB, which is slightly more than your Micca's at 85dB.
My Lepai Tripath gives off a bit of a hiss at very high volume - most evident on pauses between tracks with the volume turned up.
How loud is it?
Its very faint and not really that much of an issue, I have another small smsl amp on the way so I will compare it to that and see if theres any difference.
