sn25p with custom vga coolers?
Hi LabR@t, I had an X1800 XT with stock cooler in an SN25P and by my rough and ready reckoning the V900 will fit no problems. if anything it'll be a tidier fit than the stock cooler mate. go fer it fella
well I have just ordered the sn25p+ wifi adapter for £130 :) which I thought was cheap as chips :) looks like it fits ok :)
just fits had to cut cage, remove shrould and bend a few fins but fits and keeps it all cool . can find spare fan header so i can use fan mate though !
gobsmacked you had to do all that to squeeze her in ! how's the temps both for gpu and cpu, I removed my shroud ages ago and found temps dropped a few deg's lol
yer i thought the exact same mate, it just seemed to circulate with my vf900 eventually just getting hotter and hotter. was affecting the temps of my hdd's as well :(
stock cooler back on and we good to roll :D
