SN85G4 cold boot/shutdown issues.
16 Jan 2003
Solihull, W.Mids.
I just got my new shuttle from OCUK.
All built fine, installed XP fine.
Every now and then, from cold boot, it either freezes at the POST screen or boots to windows and resets itself.
On two occaisions now, it has froze while shutting down too.
Any ideas ?
I have reseated the RAM, checked all connections etc.
I have updated to the latest BIOS.
SN85G4 V3
XP3000 64
Radeon 9800 Pro
2x 512MB Crucial PC3200
1x 80GB SATA HD
1x Pioneer DVDRW
Hopefully not another RMA, it costs me a bloody fortune to return it.
checked temperatures???.
if you can get into windows, set the error checking to "Dont Restart" so you can see what the blue screen says
OR
check the event log in admin tools in control panel
Here is what i found...
Event Type: Information
Event Source: Winlogon
Event Category: None
Event ID: 1001
Date: 02/02/2006
Time: 12:17:49
User: N/A
Computer: ATHLON-64
Description:
Checking file system on C:
The type of the file system is NTFS.
One of your disks needs to be checked for consistency. You
may cancel the disk check, but it is strongly recommended
that you continue.
Windows will now check the disk.
The two index entries of length 0x68 and 0x68 are either identical
or appear in the wrong order.
f1 09 00 00 00 00 01 00 68 00 58 00 00 00 00 00 ........h.X.....
1d 00 00 00 00 00 01 00 00 60 db 8f d1 7e c4 01 .........`...~..
00 60 db 8f d1 7e c4 01 de 18 39 99 b5 22 c6 01 .`...~....9.."..
d6 0f 94 30 2f 27 c6 01 00 e0 05 00 00 00 00 00 ...0/'..........
00 d8 05 00 00 00 00 00 80 10 21 cc 5f d3 c5 01 ..........!._...
be 51 f0 72 6f 00 6e 00 40 28 82 67 cd 27 c6 01 .Q.ro.n.@(.g.'..
00 40 01 00 6c 00 6c 00 54 00 00 00 00 00 01 00 [email protected].......
78 00 65 00 00 00 01 00 73 00 74 00 00 00 01 00 x.e.....s.t.....
1e 3b 00 00 00 00 02 00 68 00 58 00 00 00 00 00 .;......h.X.....
80 10 21 cc 5f d3 c5 01 be 51 f0 72 bb 22 c6 01 ..!._....Q.r."..
40 28 82 67 cd 27 c6 01 00 40 01 00 00 00 00 00 @(.g.'...@......
00 3c 01 00 00 00 00 00 20 00 00 00 00 00 00 00 .<...... .......
0b 03 66 00 6f 00 6e 00 74 00 73 00 75 00 62 00 ..f.o.n.t.s.u.b.
2e 00 64 00 6c 00 6c 00 f2 09 00 00 00 00 01 00 ..d.l.l.........
70 00 5a 00 00 00 00 00 1d 00 00 00 00 00 01 00 p.Z.............
Sorting index $I30 in file 29.
Unable to query the name of a file name index entry of length 0x58
of index $I30 in file 0x850 with parent 0x1d.
00 60 db 8f d1 7e c4 01 40 2a 6b 99 b5 22 c6 01 .`...~..@*k.."..
18 58 39 3d f2 27 c6 01 00 50 00 00 00 00 00 00 .X9=.'...P......
00 4e 00 00 00 00 00 00 20 00 00 00 00 00 00 00 .N...... .......
20 00 00 00 00 00 00 00 68 00 65 00 6c 00 70 00 .......h.e.l.p.
2e 00 64 00 6c 00 6c 00 cc 0d 00 00 00 00 01 00 ..d.l.l.........
68 00 58 00 00 00 00 00 1d 00 00 00 00 00 01 00 h.X.............
Deleting an index entry from index $I30 of file 29.
The parent 0x640062006b0309 of index entry kbdda.dll of index $I30
in file 0x1800 is incorrect. The expected parent is 0x100000000001d.
Deleting index entry kbdda.dll in index $I30 of file 29.
Unable to locate the file name attribute of index entry kbd깚땰⊴dždll
of index $I30 with parent 0x1d in file 0xf11.
Deleting index entry kbd깚땰⊴dždll in index $I30 of file 29.
The parent 0x65006c006f030c of index entry oleaccrc.dll of index $I30
in file 0x4200 is incorrect. The expected parent is 0x100000000001d.
Deleting index entry oleaccrc.dll in index $I30 of file 29.
Unable to locate the file name attribute of index entry ole높凟⟍dždll
of index $I30 with parent 0x1d in file 0x4df.
Deleting index entry ole높凟⟍dždll in index $I30 of file 29.
of index $I30 in file 0x9f1 with parent 0x1d.
00 40 01 00 6c 00 6c 00 00 00 00 00 00 00 00 00 [email protected].........
10 00 00 00 02 00 00 00 20 00 00 00 00 00 00 00 ........ .......
Cleaning up minor inconsistencies on the drive.
CHKDSK is recovering lost files.
Recovering orphaned file kbdda.dll (784) into directory file 29.
Recovering orphaned file oleacc.dll (1247) into directory file 29.
Recovering orphaned file oleaccrc.dll (1248) into directory file 29.
Recovering orphaned file ws2help.dll (2128) into directory file 29.
Recovering orphaned file fontext.dll (2545) into directory file 29.
Recovering orphaned file kbdcz2.dll (3857) into directory file 29.
Cleaning up 158 unused index entries from index $SII of file 0x9.
Cleaning up 158 unused index entries from index $SDH of file 0x9.
Cleaning up 158 unused security descriptors.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
Correcting errors in the Volume Bitmap.
Windows has made corrections to the file system.
80027765 KB total disk space.
20979072 KB in 33349 files.
10572 KB in 3295 indexes.
0 KB in bad sectors.
106549 KB in use by the system.
65536 KB occupied by the log file.
58931572 KB available on disk.
4096 bytes in each allocation unit.
20006941 total allocation units on disk.
14732893 allocation units available on disk.
Internal Info:
b0 90 00 00 2f 8f 00 00 23 c1 00 00 00 00 00 00 ..../...#.......
f8 02 00 00 00 00 00 00 bc 04 00 00 00 00 00 00 ................
b2 ba dd 00 00 00 00 00 76 bb 7b 1b 00 00 00 00 ........v.{.....
0a 40 ea 02 00 00 00 00 00 00 00 00 00 00 00 00 .@..............
00 00 00 00 00 00 00 00 78 87 8e 26 00 00 00 00 ........x..&....
99 9e 36 00 00 00 00 00 78 38 07 00 45 82 00 00 ..6.....x8..E...
00 00 00 00 00 00 76 00 05 00 00 00 df 0c 00 00 ......v.........
Windows has finished checking your disk.
Please wait while your computer restarts.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
And this error appears a lot...
Event Type: Error
Event Source: EventSystem
Event Category: (50)
Event ID: 4609
Date: 02/02/2006
Time: 12:18:04
User: N/A
Computer: ATHLON-64
Description:
The COM+ Event System detected a bad return code during its internal processing. HRESULT was C0000005 from line 44 of d:\qxp_slp\com\com1x\src\events\tier1\eventsystemobj.cpp. Please contact Microsoft Product Support Services to report this error.
Whats it all mean ?
havnt a clue lol. couldbe hard drive related??? maybe the Sata cable is a bit dodgy as there were dodgy sata cables with the SN25P a while back.
and about the blue screens, windows is automatically set to restart if it detects a problem, what i ment was turn the restarting feature off when it detects a porblem, then it will show a blue screen instead usually displaying some info that you can google to find a solutoin of at least find out why it srestarting/freezing
Today I noticed that if I get the black screen before it reboots, then the monitor light flashes. (no signal)
Also, on booting today, I got corruption on the screen.
Could this be a PSU issue not being powerfull enough for the radeon ?
Radeon is fine in other PC.
