Snapped bottent release catch :-(
7 Apr 2009
Greenock, Scotland
So Iv just snapped the bonnet release on my Civic EP2. Do I need to replace the entire mechanism including the cable or can I just get the actual catch?
Its just the actual release lever I need. Thanks
depends where it is snapped. is it the lever itself that is snapped? if so does the cable disconnect from the lever? If the cable disconnects at the lever then you'd only need the lever obviously.
Printed out a replacement on the 3d printer. Turned out pretty good. Thanks for the help
