sneeze stains
22 Oct 2004
Right i was wondering how do clean a flatscreen monitor without damaging its sensetive screen. I know u cant use everyday polish so what do i use.
EDIT: EVERYONE WHO LOOKS AT THIS PLZ RATE IT 5 STARS BASED ON MY TITLE IT WOULD BE PRETTY FUNNY. :p
lol loving the title, in fact I would like to know what is best to use too.
You can buy screen wipes, but I believe there may be a cheaper/homemade solution?
Must admit I had a laugh when I saw the title. :D
Its easy, make sure the monitor is off and if it has the power brick inside, wait for it to cool down as the screen will be warm. Use a very soft cloth well wrung out in warm water with just a drop of soap added to the water. Wipe the screen several times so that its still showing damp all over, then quickly buff with a soft dry cloth.
My sons laptop often arrives at my home with all sorts of crud on the screen, I've been using this method for two years and still not a mark on it, polishes up as good as the day it came out of the shop without the slightest streak.
