Sniper Elite settings
  • Thread starter Thread starter ajm
  • Start date Start date
Well when i put my settings to high i get problems as shown below
Found these for the game
Minimum spec:
1Ghz CPU
GeForce 2 32Mb
256 MB Ram
DX8 compatible sound card
DX9.0c
Win 98/2000/ME/XP
4 Gig free hard drive space
DVD drive.
Recommended Spec:
1.4 Ghz CPU
Geforce 4 TI 32Mb+
51B MB Ram
DX9.0c
Win 98/2000/ME/XP
DVD drive.
Should this not allow me to play with everything turned up to max?
I played it at work a bit.. on
P4 3ghz,
X800 PRO 256mb
2gig RAM..
But it stil went a bit wibbly at the highest settings.. But silky smooth 1 notch down so i think its just an issue with 1 setting causing it to chuck..
Dunno for sure tho.
Ok thanks i will try 78.01 drivers.I have already tried 77.77 and now using 81.98 so i will give it a whirl. :confused:
Right i tried 78.01 drivers and things seem a little better but still can't play on high settings.
Is there any other game out there that will test my graphics card to make sure it is not at fault some where?
Thanks Rob, i tried that with 3D mark 06 and never showed anything but i don't think it fully tests the cards (Like AA).
