Sniper M5 PCIe Q
Have you got the latest BIOS on the board? think its F8a current at tweaktown forums.
Is the system overclocked? try resetting the BIOS back to defaults.
I got the latest F7 and flashed immediately. Ive mildly OC'd the CPU to 4.2, I don't see how this has any bearing on the PCI slots though ?
Code 15 says "pre memory north bridge initialisation"
Can you reseat the RAM or try other slots?
Is the RAM at stock?
Try a single stick of RAM and move it around the slots.
Yup, tried all that.. Its at stock and Ive done a bios reset to no avail.
Press F2 to bring up the old BIOS, then go to M.I.T, the miscellaneous settings, then PCie slot configuration.
It should be there, the options are Gen1, 2 or 3
Any more suggestions on this please, would be grateful. I'm close to sending it back otherwise, because my wifi card is useless.
Cheers
