Before anyone says, I have already searched and looked through a few threads.
I'm after a cue, primarily used for pub pool because I don't like many of their cues. Some are in awful condition (varies from pub to pub) and its weird using different ones all the time. I've heard that the best way to go is to buy your own cue and stick to it, so that's what I plan to do.
Now, the problem is, there are no dedicated snooker/pool shops in my local area, so I can't really try before I buy. There is a snooker club which I go to every now and again, and they do sell cues but I don't know how suited these would be for pool. I'm quite happy to use the clubs cues when I'm there, but if I had a cue that worked for both pool and snooker, that would be great.
Can anyone point me in the right direction? I'm not a total beginner, and I can play semi-consistently and I'm looking for a personal cue so that I can get used to the feel and not screw up when it comes to more difficult shots.
I also don't want to spend more than £50.
Once in pre-match practice and witnessed by my team mates and several of the opposing team I made four break clearances out of five breaks. But for the life of me I never managed the magical three straight. That still niggles me now.
But those cost. Also ideally you want a two piece cue with the joint at 3/4 length nearest the butt and with the male joint on the smaller end. That way you can take the small bit off and be left with a short cue for those annoying places in pubs where you have difficulty fitting in a whole cue. Yet again that costs. Things to bear in mind for down the road though.
Riley make some cues with 9 to 9.5mm tips. So pick one of those. I'd also suggest you make sure it has a Blue Diamond tip on it. Some folks like Elkmaster tips but for Pool a Blue Diamond is usually better. Tips are easy to change. If you've never changed one then the best way is with standard SuperGlue but remember to dampen both the tip and the cue end slightly with water first. That helps the glue take. Also grab yourself a cue file for once its set. Tips are too hard cornered when you fit them at first. What you want is a gently curved shallow dome, a bit like an upturned saucer.
