Hi,
I have a Macbook Pro 2007 2.4 and i just upgraded to snowleopard from tiger (which is worked perfectly after updates) and now i cannot get a wireless connection, i sometimes get it intermittently but not very often. I did a clean install, and when it asked me to connect to a network it did but after i updated the software it out right refuses to connect, it can see the SSID but i get "connection timed out". Our router is currently on a WEP password and i know that this might be the problem but out router does not support WPA very well. I know its not a router issue because i have 4 other PC on it working fine. I have tried deleting internet pref's cleared DNS cache etc, but no success. Is anyone else with a 2007 MBP having these issues?
Any help would be appreciated.
Thanks
Matt
Thanks
Matt
