SNR up decreasing
14 Dec 2005
Sync is about 12000 down 1000 up on adsl2+
The SNR down is 14, SNR up is about 6 immediately after restarting the router, then stays between 2 and 3
Attenuation is about 14 down, 23 up
Problem I'm having is random disconnects, works fine when its connected.
Does this sound like a faulty router problem?
If the SNR is that low it wouldn't take much to cause the connection to drop. Are you deliberately driving the SNR down to increase the line sync?
the opposite, stability adjustment set to -7 to try and stop the dropouts
for months it was set to -3 and was fine, stayed up for weeks.....only in the last week or so it's started to disconnect
so something's wrong somewhere....Zen tested the line from their office, all seemed OK
the SNR figure dropping like that seems suspicious, what could cause it tho?
it never used to go that low
