- 24 Sep 2009
- Surrey
Utter bo**ocks, group one metals do not cause explosions in water bath tubs by 3cm burettes of substance /end rant
2 M (s) + 2 H2O (l) → 2 MOH (aq) + H2 (g)
If M is the chemical symbol for the element in Group 1 of the periodic table (lithium, sodium, potassium, rubidium, caesium, francium), do they ALL follow the same pattern?
In the interest of scienceeLbot said:The answer is unfortunately both yes and no depending on what level we're discussing this at.
)) can you give us some more detail?I'm stating the obvious here, but this didn't seem to be the case in Vinni3's YouTube link. Lithium to potassium are less dense than water and thus float; rubidium and caesium are denser and would sink.Aod said:yep. the reaction is so quick and powerful that the metal is completely surrounded by bubbles of gas allowing the sample to react quite slowly, actually.sara said:As I understand it - Caesium and Rubidium ARE chemically more reactive - but they give off so much Hydrogen that they bounce off the water on a cloud of gas instead of hanging around and fizzbanging.
Okay it's late but I don't think that even in layman's terms this provides a suitable answer as written. I got to see the demonstration for myself in year 9 but I don't recall the depth of the explanation and right now I can't think of how I would explain it without invoking electronic configurations.flibbage0 said:The reason why they get more reactive is because as you go down group 1 in the periodic table, the number of shells increases and so does the shielding and atomic radius also increases.
think we've all seen that video at school![]()
and now the truth:
I wouldn't refer to MOH as a salt, I'd reserve that for the product of reaction between a metal and a mineral acid.As far as year 9 go it doesn't need to be in any depth really, they just need to know that a metal + water -> salt + hydrogen and then how to name the salt.
The reaction is very favourable since the loss of the lone valence electron affords a noble gas configuration. It seems logical that increased reactivity corresponds to the rate at which the reaction proceeds; it might not be necessarily true that caesium has more energy to give out than lithium but it does so in a shorter timespan. Possibly for a couple of reasons the activation energy decreases on decending the group and for simplicity we could just consider the ionisation energy which decreases as that valence electron is, relatively speaking, much further away and less tightly held. Now, with an increase in reaction rate prescribed for a decrease in activation energy we can justify the observations.
