So for that last few times been playing some CS:GO and all of a sudden it starts jumping, going really slow and have no idea what it is when i check my memory usage, its sky high even tho i have 8GB of Ram
Your probily experiencing a rather common memory leak associated with win8.try this fix
Goto Search and type 'Regedit'
Open the app and search for this location
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\N du\
In the right had window select the start entry and change its value to 4.
Then restart your PC.
Your ram speeds need to configed in your bios by enabling their XMP profile
Once in the BIOS click the Memory tab and there should be a option to load the XMP file, allow this and save and you should have the ram at the correct speed.
After doing change in registry there was an error msg didn't take picture as was late but will take picture when come if happens again and will do bios aswell
Your mem usage in the above screenshots looks normal,you got some other stuff open too razer software/samsung magician/killernetworking ect.So about 2Gb usage is about what to expect.
Edit: I just noticed you have igfxcuiservice running?,thats for the integrated graphics on the CPU,you should probily disable/uninstall that as you have an nvidia card installed
