So confused, spec me a GFX
Permabanned
28 Mar 2011
Space Man INIT
Am running the following
Zotac Z68 ITX
2 OCZ Agilty 3 60GB SSD's
i7 2600K with an OC to 4.5
It's all powered by a Seasonic X-460FL (460w).
Then the case is a Lian Li Q11B. I can fit a GFX card length of 260MM.
Wanting a nice decent card but nothing super super to take strain off my CPU's HD3000.
Have no idea what to go for.
Idealy something i can get a full cover block for (ek block idealy)
HELP please
Im in the trade so budget doesn't matter as what ever retail is i'll get it for lots lots less :)!!
Card needs to be 260mm to fit!
Edit, looking at XFX's site seams it might just fit!
Dimensions (Imperial): N/A 10.3 x 4.4 x 1.5
Dimensions (Metric): N/A 26.2 x 11.12 x 3.81
Problem is your PSU :(
not the most capable for the higher end cards.
Erm...Seasonic is the best brand around, don't think 460W would have any problem running a system with a single graphic card that use no more than two PCI-E 6-pin, even with the overclocked i7 2600K.
Got a good review here as well:
http://www.anandtech.com/show/3962/seasonic-x460fl-460w-fanless/9
But to be honest, I'm not sure why the OP would wish to not use the HD3000, if he is not gaming...
The case i hope arrives on Thursday if the supplier pulls there fingers out!
Everything online is saying 260mm.
I can move the power plugs no problem, bit of soldering is easy!
I was talking about high end in that 8 pin and 6 pin cards which o was a bit wary of speccing with a 460w. Even if it is by the best brand ever :p
i really wouldn't. Voids your warranty. It's probably best to get the case first to make sure it fits. A GTX 570 might just fit :)
I never had anything refused warranty. I always get it replaced. I'd make up 2 new conections with them being vertical if there on the end
And what high-end card that uses 6pin+8pin that is shorter than 260mm in length? :D
GTX570/6950 are 267mm, and higher card ain't gonna get any shorter neither.
>Danfoss2011
I think the Sapphire 5850 Extreme is probably your best option, considering it's only 215mm in length:
http://www.bit-tech.net/hardware/graphics/2011/06/10/sapphire-hd-5850-xtreme-1gb-review/
