So i got a kolink deathclaw case and need help
10 Dec 2015
Halifax Uk
Right a month ago a mate upgraded his pc which meant i got his old one as was better than i had anyway i decided to get another case aswell as mine has seen better days so looked and decided to get the https://www.overclockers.co.uk/kolink-deathclaw-midi-tower-gaming-case-black-ca-008-kk.html it was in my budget and looks quite cool.
I know you get what you pay for and if its cheap theres a reason why its cheap but hindsight is a well you know. Also with them now stopped selling it im guessing a few complaints regarding the case.
Anyway he got the case and went over to fit new bits into it and i cant work out how im supposed to fit the hard drives in place for 2 hours we were confused as where we thought it could go there's a gap of near 1/2 inch on one side and i know the hd is supposed to be fixed tight. It looks like there's supposed to be hard-drive sliders in place but there wasn't any and in the pictures there dosnt show to be any.
So we ended up fitting the hd to a slot where a disk drive is supposed to go at the top which i know isn't ideal but its the only place we could get all the screws in.
Now im wanting to fit another hd for more storage and im stuck as i cant work out how to do it yeah i could bodge it with cable ties but i dont see why i should have to.
So im wanting to know is there anything i could get so i could fit other hard-drives well apart from another case but atm im thinking that as would be sooo much easier and whatever case i go for would be at least made better than this.
Ideas people cheers
I think you need to contact OCUK. this case is basically unbranded and only sold by OCUK and caseking (parent company) there is no info on the internet anywhere about this case apart from these 2 websites. no pictures either with it containing components. from the photo it does look like the HDDs are meant to have mounting rails and slide in. It maybe they were missing from your case. in any case I should contact OCUK and RMA as its no longer supplied, and get a branded one
My basket at Overclockers UK:
Total: £147.58
(includes shipping: £14.70)
Hey cheers for the reply.
I did email them and not heard anything back its been around a month. The only problem i know is a mate ordered it as he did a order with them so it was wise to put the case on the order than do it by its-self and i paid him so either they will only contact him i dont know but will try contact them again...
I suggest you start a thread in the Component Technical Support forum. Be sure to give the order number.
Hopefully this is a very silly question indeed, but did you check the box in which the case came for another box of screws and parts?
