- 5 Sep 2005
- Northern Ireland
Hi guys,
So I went and locked myself out of the router (don't ask
), and had to reset the damn thing, then I needed to re-flash it with a different version of DD-WRT anyway (for OpenVPN, if i can ever get build-dh working).
But of course muggins here forgot to save the settings on the router before the reset and re-flash, so it's all gone a bit pear-shaped here.
To add insult to injury, I've mis-placed the lovely document that had all my hostnames and IP's in it, as far as I remember I have the PC's set up to be static IP's, by changing the network properties.
I may as well re-set everything to hold IP's for each machines MAC address on the router itself anyway, yes? As it is at the minute, under DCHP clients it lists nothing, which is somewhat unhelpful.
So is there a wee command line thing or something I can run in Win XP that will spit out the IP addresses of the machines that this PC can "see" on the network, so I can get all the port forwards back up and running again?
), and had to reset the damn thing, then I needed to re-flash it with a different version of DD-WRT anyway (for OpenVPN, if i can ever get build-dh working).But of course muggins here forgot to save the settings on the router before the reset and re-flash, so it's all gone a bit pear-shaped here.
