So I heard a chattering noise coming from inside my 650D....
  • Thread starter Thread starter mrk
  • Start date Start date
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
I moved the tower to the side so I could take a look through the window and inspect....sounded like it was coming from the front and not the PSU like I thought so I took the side panel off and noticed A SPIDER BANGING AGAINST THE 200MM INTAKE!!!.
I grabbed the closest thing I had (a block of post it notes :eek:) and attempted to stab it but it just crept closer to the fan behind one of the pillars (see pic below) so it was hard to grab/squash. I ran downstairs faster than a Neutron so it didn't have time to hide hide, grabbed the vacuum and sucked that mother right up before I even ran down stairs ;)
It also gave me an excuse to de-dust the innards and filters as it was the time of the month but damn...I never once expected a grown spider to be able to squeeze inside there...it must have gotten in through the underside as the 650D has some holes for screws and brackets that are just large enough for a bug to get in so I also patched those up with black electrical tape.
The bugger must have been there a while, I notced lines of web sprawling from the GFX card, down the power connector to the HDD cage then ending at the intake fan.
Not entirely.
So you had a spider in your PC?
Shows you take great care of it.
Insects can get anywhere, now matter how clean you/your house is FACT.
This chap may have a spider in his PC however it does not mean he neglects it in any way.
Scientifically a computer would be one of the preferred habitats for an insect if it were to venture into your house; as they are usually warm and dry.
Clearly you have not seen pics of my PC or set-up or how I keep stuff :p
Anyway, it's logical a spidy would find its way in there as mentioned above^ I never turn my PC off so there's always a constant source of warmth bugs might be attracted to and then there's there's the electrical "radiation" that bugs are attracted to as well.
