Ok, so I want a VR/Gaming PC (with RIFT s) and I want to build it myself (....with some assistance from you guys)
As a little background, I used to build PCs and even sell them to friends and family, but that was almost 30 yrs ago now and KA9Q is no longer required to connect to the internet!!
Clearly a lot has moved on, and I've done a fair bit of research, but im sure that wont preclude me from the odd terminology gaff, so go gentle.
Project Decisions so far: (feel free to comment, but probably won't budge)
1. Expecting project cost upwards of £4000
2. I would like to OVERCLOCK (primarily for curiosity than extreme performance)
3. I Will use Intel CPUs (memory of too much pain in the late 1990's, early 2000's - I appreciate the Ryzen Threadripper are very very different these days. Perhaps in another build)
4. It must fit inside Corsair Crystal 680x (ATX mobo) as I liked it and already bought it
5. Low Noise is important, but doesn't need to be silent. (again, not looking for extremes)
6. RGB isn't required
Assumption (...Please correct if they're dumb)
1. I will simplify my life (and Cost) if I DON'T SLI - feels like the benefit isn't massive and the effort to tune will plus reduced gaming support outweighs the benefit (to me). My assumption at this time is to buy a single RTX 2080 TI 11GB (Probably Gigabyte)
Questions
1. Can I achieve 5GHz overclocked CPU with air cooling alone. -- Not certain so at this time I am thinking water cooled CPU with Corsair Hydro (or similar) and standard air cooled RTX 2080 Ti.
2. Should I go X299 or X390 - is there any real benefit for my VR/gaming PC given I don't want/need SLI.
3. I have a preference for mirrored OS disks and plan to do so with 2x M.2 NVME devices RAID1'd - Will this reduce performance, enhance performance or be exactly the same as 1x M.2 NVME (I dont want cost / MTBF taken into the consideration, just performance and impact on overall system
4. If I go one or two NVME (say 500GBs) is it normal to then have two tiers of storage using more traditional SSD (~2TB) as a second tier, and then third tier of storage (>4TB) for large volumes using spinning disks.
5. What have I not asked?
Thanks in advance and looking forward to you input.
Rich
Questions
Rich
