So, it was worth the upgrade.
12 Sep 2005
Grundisburgh
3770K to 5930K
Z68 to X99
DDR3 to DDR4
SSD to M.2 SSD
First impression in Fallout 4 Ultra with some things turned down 45-60 fps is now 70-75 Ultra with pretty much everything Ultra, Godrays High!
3DMark Firestrike is 33% faster.
Andi.
I can only imagine what upgrading the CPU in my sig to a 5820k would be like!
Do you reckon your upgrade speed increase was due to the CPU or m.2 drive though?
I think its a bit of everything, better mobo, ram and more CPU cores. Each on its own I don't think would have made much of a difference hence it was a risky and expensive upgrade.
Andi.
Mobo layout without the video cards
And with
With the last PCIe x16 disaqbled by the M.2 SSD there is only a X1 slot between the 980TI's left.
A USB adapter may be the answer depends on how much I lose byt adding 2nd monitor to the SLI.
