So looking for tv advice
19 Mar 2011
Currently have a panasonic 50" plasma active 3d tv supposed to be smart but lets say its not as smart as some tvs for example i had to purchase a seprate item to access netflix. Anyway had this tv for almost 5yrs now and am thinking of getting a new tv, seen lots of makes and models and while nothing is standing out in the crowd i thought i would ask here for advice.
3d is not needed anymore
50-60" would be wanted
flat of course, plasma not a must
access to netflix and freeview built in
4k or uhd not sure whats best
price wise i could go as much as £1500 am uk based so my store options are limited to our favorite friday night takeaway store Cu**ys :)
any advice appreciated
Well they dont make plasma anymore Chili so your options are either LCD or OLED but you would need to up your budget for OLED as they are currently around £1900 for the LG B6 they may come down a little more but nobody knows for sure yet.
4K is UHD chili and 3D was dropped from most tv models anyway so no problem there.
As for models to look at i suggest you go and look at the Samsung 55" KS7000 at your local store.
http://www.samsung.com/uk/tv/KS7000/?modelCode=UE55KS7000UXXU
The Sony KD55XD9305 is another good option but its slightly more expensive than the samsung but its another option to look at and compare.
If you can stretch to an OLED like the LG B6 then that would be my recommendation personally.
