So much Bling
We shall be stocking these, had a play in June with them, in the flesh they look amazing, but yes the bling factor is real, chrome looks best.
Probably be in stock Dec/Jan, price shall be eye watering, proper elite tier, you want it, you pays for it. :D
Performance to match the price as well, or is it just for looks?
Both its an all out hero kit, only screened B die to begin with and all kits should be north of 3200MHz, its hero stuff, not volume production, not yet anyway.
We are working with them for hopefully some 4266MHz kit on this. :)
Spoke with G.Skill
All ordered and they are going to do 3000MHz upwards, so setup a few SKU's are our choosing which shall go online in December.
Here's another look at these memory sticks.
I have to admit, i'm not a lover of anything rgb lighting wise and have everything i can turned off on my CH6. But that ram looks absolutely gorgeous.................almost certainly will have a price tag to match as well i would imagine.
i like the gold but the light spreader looks like cheap fake bling jewlery not worth £1.
You could probably make something like this spray paint on gold colour and some super glue with cheap bling crystals from the bay.
for that essentially G skill are going to charge most probably extra 30-40% price increase with practically no performance difference.
anyone else grind their teeth to see the barcode labels on the heat spreaders? i'd want a flawless unstickered finish :(
