Long story short, I recently got a second hand AMD FX 4100 from a friend which I purchased a new MSI P23FX mobo for.
I have been using a pretty cheap 500watt psu that I got free with my case due to the fact that the better one I bought would not fit in my case.
This cheap PSU was working fine for nine months with my old mobo and CPU (Intel Celeron Dual Core LGA775), but hours after I installed my new CPU and mobo it blew out on me.
Now I know what you are thinking, "this guy needs more than 500watts" but I'm not so sure...
The friend I got the CPU from was running the same setup as me on 450watts with no problems...
CPU: AMD FX 4100
GPU: Nvidia GeForce GTX550ti
RAM: 4GB DDR3
HDD: x2 5200rpm (One is a 2.5mm one is a 3.5mm, crappy I know..)
CD/DVD Drive: Cheap Samsung
I haven't OC'd anything..Yet.
I also used a psu calculator online, entered all my specs and apparently I only need around 380watts?..
So I'm currently running on the better psu I mentioned earlier that originally wouldn't fit in my case and everything seems to be alright so far (after a few hours), I haven't tried any demanding games such as IV or BF3 in fear of it breaking again.
Anyway, here are the things I narrowed it down to...
- I don't have an anti-surge adapter, my current adapter is about 7 years old
- When cleaning my case out with canned air, I stupidly directed the air inside the old psu which blew dust off of the fans into the internals of the psu.
- Worst-case scenario (as I don't have money atm) 500watt is not enough.
Could anyone tell me what the problem is/was?
Whether it was a power surge, or a crappy psu/overheated psu..
CPU: AMD FX 4100
RAM: 4GB DDR3
