So should I be worried about this with no one connected by wireless??
19 Oct 2002
Are you referring to the received and transmitted packet statistics?
How long has it been running? It could just be the result of WiFi enabled devices within range simply polling the router for information.
13,000 packets in the grand scheme of things is very little. Certiahnly does not represent active usage.
If you are worried, change the WPA key.
